Which Kickers should i go with (JONATHAN/ ANYBODY)
ctb
I have heard that kicker solo baric l7's dont hit as good as they are said to. I have a choice b/w (2)L7's, (3)KickerCVRs, &(2)Alpine Type R's. What do you suggest i go with. I just want the loudest and hardest hitting combo of these and it will go in a Chevy Trailblazer
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1050
are they 12's or 15's
Username: Subman15
Lwarenceburg, Kentucky United states
Post Number: 16
are you talking about 15" subs?
Los Angeles, CA USA
Post Number: 218
i have 2 12inch alpine type Rs with a kicker kx1200.1 and it is loud and clear.
Post Number: 1054
and if there 12's why not get 3 l7's
Los Angeles, CA USA
Post Number: 221
why not 2 re sx 15 inch with kicker kx2500.1
hgill
oh sorry bout that, there all 12"
i wont get 3 l7's because of price difference
ctb
im talking about 12's
i wouldnt get three l7's because of price difference
Username: Cenus
Hicksville, Ohio Usa
Post Number: 614
well i would get 3 cvr's.
Username: Six
Flint, MI U.S.A.
Post Number: 174
3 SE's....
Post Number: 1083
6 re re's with a kicker 1200.1 would sound good
