Can front or rear speakers share a (-) connection?
Username: Durango
Hi all,
My 82 280zx is getting a new radio, The wiring thats is setup for the stock radio has the front and rear running on the same (-) wire. Can you do this with a modern HU?
Username: Tekniqal
Flagstaff
Post Number: 48
I dont know for sure but isnt this just wiring your speakers in parallel? I think you can do it.
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 42
NO!!! thats an old common ground setup, run new wires. It may work but it won't be good.
