CAN SOMEONE EXPLAIN THIS EASIER?????
when you buy the speaker wires, do you have to get 2 of them and then hook them up to the sub terminals and then from those same terminals, wire the wires together? I need to parallel bridge my amp to my subs... Can someone explain this easier on how to bridge the sub parallel????
my amp is 2-channel 2 ohm stable and i have (2) 400 wat RMS subs My amp is 800 wats when bridged...
wheh you buy speaker wires do they come in negetive and positive... please help i'm confused
THEN U MUST READ SITE THOUROUGHLY A FEW TIMES
www.bcae1.com
Username: Jmloughrey
Farmington, CT
Post Number: 1385
yea www.bcae1.com read over several times...several hundred times.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 696
are your subs 2 ohm or 4 ohm
each 4 ohm
