JL w6v2 12" with a 800 watt Audiobahn Monoblock amp?
Username: Devildeg
Lone Oak, Tx USA
I was wondering if my 2 JL w6v2 12"s will sound good with an 800watt Audiobahn Monoblock amp. I will make a custom box that is an exact replica of the "superb" JL boxes that are on their site. And i wanted to know if $400 is a good buy on 2 12" JL w6v2? Also, any other suggestions......
Thanks,
DevilDEG
Username: Loc_out
Post Number: 281
You could use a better amp. What is your budget?
Username: Rovin
Trinidad & T...
Post Number: 1640
I personally would never put any Audiobahn amps on a sub with a calibur like JL - though others would disagree .
Is that $400 for used subs & how much will u spend on a amp ?
I'd get a good 100wrms brand name amp for those ...
Username: Devildeg
Lone Oak, Tx USA
Not very high, a friend wants to sell me his amp, the one mentioned above, for around $200. I can't spend more than $220 on an amp right now, cause the speakers are soo expensive. But I think I'm getting a good deal on the subs....what do you think?
Username: Devildeg
Lone Oak, Tx USA
Username: Rovin
Trinidad & T...
Post Number: 1642
those subs new online are $340 each so if those are in good condition & u know the guy then yea ...
for that low budget go ebay - look for a used 1000wrms @ 1ohm Orion, JBL , kicker ,Mtx , Alpine etc
Username: Devildeg
Lone Oak, Tx USA
And do you guys think that i should use a closed box, or some other kind? Either way, I'm making it so any tips on board and what to use and not to use would be great.
Username: Rovin
Trinidad & T...
Post Number: 1643
If u want it loud go ported using JL's rec specs & i personally would use 1" thick mdf - though others on here would say 3/4 would work
Username: Devildeg
Lone Oak, Tx USA
Thanks guys, your alot of help! Any suggestions on how i should hook it up? And exactly what amp to buy that would be the best for my subs?
Username: Devildeg
Lone Oak, Tx USA
Post Number: 7
so is 3/4 plywood good? or should i use some other type of board, I have the plywood....
Username: Carguy
Post Number: 4876
You need to use 3/4" MDF, not plywood. Go visit Home Depot, they should have some.
Username: Rovin
Trinidad & T...
Post Number: 1644
Do not use ply as it has air gaps in it .
best amp for it would be JL 1000/1 which is $700 ! - lol
those subs are 400wrms 4ohms DVC subs which can be hooked up like this Upload
with a 1000wrms @ 1ohms like
MB Quart raa1000
PPI DCX 1000.1
Rockford Fosgate T10001bd
Crossfire 1000
Diamond audio D61000.1
JBL BPX1100.1
Memphis 16-MCD1000
are just a few examples . Average costs around $350 & up !
Username: Suleman36
Maryland U.S.A.
Post Number: 2317
Im powering my 2 JL 12w6v2's in the sealed prowedge box powered by a CrossFire VR1000D and it sounds very nice and the SQ is second to none.
Username: Devildeg
Lone Oak, Tx USA
Post Number: 9
SWEET.....you guys are awesome!
Username: Rovin
Trinidad & T...
Post Number: 1649
