Alpine MRD-M1005. Good or No?
Username: Moondog1212
New York United States
Post Number: 36
hey just wondering how good of an amp this actually is.
Username: Need4bass
We-Be-Swamps, Louisiana
Post Number: 96
I have one pushing 4 8s. It does what it claims. It bench tested a little above it's rated output. It never shuts down and runs very cool, even when driven hard.
Username: Jdizzle123
i want to know if i can make two 10'' type r's sound good and loud with a alpine mrd-m605 they are in a sealed box and runing in paralel if they wont then ill just buy another 605 and run one amp two each any sugjestions?
Username: Need4bass
Post Number: 105
2 605s would be the way to go. That would be very nice.
Post Number: 39
i was thinking about doing the same thing, but i have 2 12" type R's, just wondering what would be better the 2-605's or 1-1005? thx for any advice or comments.
Username: Need4bass
Post Number: 115
I still think you'd be better with the 2 605s.
Username: Rovin
Trinidad & T...
Post Number: 1700
If u wanna keep it Alpine on Alpine - i agree on 2 605 , your subs must be 4ohms dvc though .
Post Number: 40
they are 2ohm dvc, so then what should i do?
Username: Need4bass
Post Number: 143
So they are the SWR-1022Ds ?
You can wire the coils in series and then to the amp. This will give a 4 ohm load. With the 2 605s each sub would see only 250WRMS @ 12V and about 350WRMS with the car running. Those subs are rated at 500WRMS each. You could get just one MRD-M1005, wire the 2 coils of each sub in parrallel and then wire each sub in series with the other and present the amp with a 2 ohm load. In this case the MRD-M1005 will provide 700W at 12V and 1000W @ 14.4V.
Post Number: 42
no they are 1221Ds(older model), sorry. 350wrms.
Username: Rovin
Trinidad & T...
Post Number: 1775
if there is 2 2ohms dvc subs u can wire em like this Upload
& buy the M1005
RMS Power (at 12V,20Hz-200Hz)
* Per channel into 2 ohms : 700W x 1
* Per channel into 4 ohms : 500W x 1
RMS Power (at 14.4V,20Hz-200Hz)
* Per channel into 2 ohms : 1000W x 1 (1% THD)
So i think its a perfect match
Post Number: 43
thanks for the advice, i will probably do that when i get some money together.
Username: Rovin
Trinidad & T...
Post Number: 1778
Ebay has some incredible deals
Username: Need4bass
Post Number: 144
I snagged mine for $350 shipped.
Post Number: 45
thx alot guys. gonna go check some out.
