Question on depth
Play_It_LOUD
is it true when building a box that you have to add 2 inches to the depth???? what happends if you dont do this????
Username: Basshead86
Ocala, FL USA
Post Number: 2471
you are supposed to add w/e the thickness of your MDF is to calculate the inner box volume.
other than that, you will have to be more specific.
for example, if your box is 3/4" MDF, then after you calculate L x W x D. you would add 1-1/2" to each measurement to account for MDF thickness, so you would get the inner dimensons of the box.
then you take that # and divide by 1728(that's how many inches are in a cubed foot) and you get the internal box volume.
make sure you take into account the drivers displacement, and the port volume(if you are building a ported box):-)
Username: Rovin
Trinidad & T...
Post Number: 1532
Rather than busting ya brain doing the math use the calculators on www.the12volt.com ......Upload
Ocala, FL USA
Post Number: 2478
Play_It_LOUD
i know all the measurment stuff but if the subs mounting depth is 6 inches do i have to add 2 inches to the depth??? and make it 8???
Username: Rovin
Trinidad & T...
Post Number: 1541
oh , u meant behind the sub itself !?
Well yea u should leave some space there 2" - i read somewhere there's a reason for doing it
Play_It_LOUD
does anyone know what happends if you dont???
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 544
the world ends
Username: Scubasteve
College Park, MD
Post Number: 712
Its actually not crucial. What you don't want is for the magnet to start smacking the back of the box. On a poorly made large box with improper bracing, I could see that happening if you don't leave a full 2 inches.
Ocala, FL USA
Post Number: 2495
it might have something to do with the backwaves of the sub in a ported enclosure. not sure though.
Username: Solacedagony
New Jersey US
Post Number: 540
Last I heard it was for cooling purposes. And when calculating your inner box volume you would take the outside dimensions of your box and SUBTRACT the width of your MDF (if .75 MDF, then subtract 1.5 from each side). The MDF isn't airspace.
Ocala, FL USA
Post Number: 2502
ahh yes, the vented pole piece. completely forgot about that.
if your sub has a hole in the bottom of the magnet that goes up through the magnet, then the back of your sub needs some breathing room.
and again, your correct, i said add, and you are supposed to subtract, but he already knew that anyway.:-O
Play_It_LOUD
hey thanks alot guys
