Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 11 Registered: Aug-05 | I have 2 infinity perfect 12.1s, and have them in a temporary enclosure, which I have no specs for. It is ported, and has no seperator in the middle... I'm only powering one of the subs right now because my front channel(bridged, infinity 7541a) does not put out near as much bass as the rear channel bridged... I'm thinking that the powered sub pulls/pushes the other sub, but the other sub has no resistance so it might damage something?.. Or am I just an idiot? |
Gold Member Username: RovinTrinidad & T... Post Number: 1595 Registered: Jul-05 | U got rid of them Volfenhags ? - lol... though i have never built a box without a separation , i would think that a sub working in a box built for 2 might end up over exerting & possibly damage itself trying to move double the amt of air . thats y 1 of the logics of building separate chambers in a box holds true so in case if 1 sub fails u will notice & prevent any damage ....... |
Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 12 Registered: Aug-05 | wrong tyler... yeah thats what I kind of thought... any ideas about the front channel on my amp? |
Gold Member Username: RovinTrinidad & T... Post Number: 1597 Registered: Jul-05 | k , didn't look @ your post number & i thought then u were that other tyler . your amp http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF7541A'&Ser=REF&Cat=AMP your sub http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12.1'&Ser=KAP&Cat=SUB u can run 1 sub / channel temporary until u do the right thing & get a mono ... |
Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 13 Registered: Aug-05 | no worries :P alright... thanks Rovin |
