Whatta you guys think of this amp? It puts out 240Owrms @ 2ohms and 1400wrms @ 4ohms. I'll be using this alongside my Viper d2500.1. Which is a better amp? How much is each worth? And could I slave one off the other? (basically the same amp 'cept the Viper put out an extra 100wrms at 2 & 4 ohms)
I ran that amp on 2 orion P15,was not impressed, also had a problem, blue lights atayed on even with car off, tuched metal casing and it would go on and off. Sent back to my distributor, also that amp s/b 1ohm stable x1200w at 14.4volts
