Amp for 2 type-R 12"
Username: Scott_t
Post Number: 30
what amp is good for 2 12" alpine type-R subs? 2 or 4 ohm?
Username: Jaackdeth
United States
Post Number: 683
What is your budget??
Username: Scott_t
Post Number: 31
around $200-300
Username: Thebigdon
Post Number: 13
are they the dual 2 ohm or the dual 4 ohm subs?
Username: Scott_t
Post Number: 32
dont have them yet so can be eather..give me a option for both or the better of the 2
Username: Tdisanto
Post Number: 453
Kicker KX600.1: get 4ohms DVC and wire in parallel and run the amp at 2ohms for 600watts RMS. (Kicker doesnt specify if thats 600 continous or peak wattage.
Or even better the Xtant A6001: Same scenario for the sub VC config. Puts out 600watts RMS
http://cgi.ebay.com/XTANT-A6001-MONO-AMPLIFIER-600W-SUB-WOOFER-AMP-NEW-05_W0QQit emZ5819152619QQcategoryZ64573QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Good deal on ebay for that xtant amp in your pricfe range.
Username: Scott_t
Post Number: 37
never herd of the xtitan brand
Username: Tdisanto
Post Number: 457
i just re-read the post and realized that there is 2 subs not one. So those amps will not work.
Try the KX1200.1 but thats gunna be out of your budget.
Username: Scott_t
Post Number: 41
everyone says that amp lol.. what about the hifonics 1500w amp or am i better off saving a lil longer and geting the kicker amp?
Username: James_g
TN
Post Number: 320
Save a little and get the Kicker amp.
By the way, Kicker does specify that their amps are rated at RMS wattage. The manuals clearly state RMS ratings and there are no MAX ratings, period. The KX1200.1 is built to put out a minimum of 1200w RMS at 1 ohm. The supplied birth sheet will give you the exact RMS output, which they list as "MAX" on the sheet.
Username: Xdream
Sherman oaks, Ca
Post Number: 25
but isnt the kx1200 a mono amp? how can they be used for 2 alpines?
Username: James_g
TN
Post Number: 321
You would use two DVC 4 ohm Type-Rs for a 1 ohm load. Wire all 4 VCs in parallel.
You can use any number of subs you want on a mono amp as long as you don't drop below the stable impedance of the amp. You could run eight 12s (or more) if you wanted to.
Username: Xdream
Sherman oaks, Ca
Post Number: 26
oh i see james. which option would be better?
1. 2 type r 12's 4 ohm with a kx1200?
or
2. 2 type r 12's 2 ohm with a alphasonic 900W x 2 @ 2 Ohms
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5819939251&fromMakeTrack= true
Username: Rovin
Trinidad & T...
Post Number: 1442
Kicker will kick alphasonic's BUTT !
I'm not being rude here but alot of amp solutions were mentioned in all of those threads concerning Type R so check that out .....Upload
Username: Xdream
Sherman oaks, Ca
Post Number: 27
i will check them out!
so if i wanna run a monoamp then i will have to get the 4 ohm versions?
and will be running them at 600rms at 1 ohm?
how will that sound? will it rock my trunk in my 05 impala? would i be able to be heard from distances? will it sound like one w7?
Username: James_g
TN
Post Number: 322
If you get the KX1200.1, then you will need the DVC 4 ohm subs. That will give you the 1 ohm load you need on that amp and each sub will get 600w RMS. Yes, they will rock.
Username: Scott_t
Post Number: 42
kk cool 2 subs at 4 ohms each with the kicker kx1200.1 amp.
thx
Username: Carolinablue637
Lincoln, NE USA
James, thanks for the suggestions, I have been reading these boards for awhile now and just now joined. I have two alpine type r 12s and i just bought that kicker KX1200.1 amp. ill post on how it sounds when i get it :-)
Username: Halter
Ohio
Post Number: 43
how would 1 an A8002T work for now...then after I save some money I get another one for 2 Type Rs
