Can someone tell me?
Headstrong
Say you have a 1000 Watt 2ohm stable Mono Amp. 2 15" DVC 3ohm subs. How would you wire them to get the most wattage out of the amp? Series, parallel, or together? All help will be greatly appreciated.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2009
take each sub and wire the coils in series.
that'll make two 6 ohm subs
wire the subs to teh amp in parallel.
that makes a 3 ohm load.
you'll get about 375wRMS per sub, if the amp puts out 1Kwatt RMS @ 2 ohms
Headstrong
Ok, thanks alot! Earthquake states that the amp can handle down to .5 ohms without getting overheated. And that 1 ohm would be great. So if that's true how could I wire it down to 1 ohm and how many watts would that be. Thanks alot!
Username: Twh1227
Post Number: 18
wire the coils paralel giving you 1.5 ohms per sub,then wire the subs to the amp paralel for .75 ohm load
Headstrong
Thanks alot Glasswolf and Todd. I appreciate it!
Username: Glasswolf
Post Number: 2037
yeah if the amp is half ohm stable, go with Todd's suggestion of straight parallel.
most amps aren't made for that which was why I was aiming at the 3 ohm load initially.
Headstrong
Alright, that's cool. thanks
