Bronze Member Username: Alexv305Tavernier, FL USA Post Number: 24 Registered: Oct-05 | Which brand of amps do you think is best for my Kicker L5 15s? They take about 1500w Max/750 RMS each so thats a total of 1500 RMS. So which amp would push them hardest for SPL? I have two of these subs. Oh and they are wired in parallel at 2 ohms per sub which comes down to 1 ohm load on the amp. MA Audio HK2000D Lanzar OPTI2000D Visonik V918XD Hifonics BX2005D Alphasonik PMA800DA Soundstream PCA1500D Soundstream PCA2000D Which brand is the best and which brand puts out true RMS @ 13.8 volts and not at 17 volts like most say. Please help me with this. I want my kicker L5's to SLAM!! |
Silver Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 492 Registered: Jul-05 | The Soundstream PCA2000D might be a bit to powerful The Hifonics BX2005D is overrated so it might put out like 1300-1400 rms, So the Soundsteam PCA 1500D might be your best bet. Those others dont even consider |
Silver Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 493 Registered: Jul-05 | Also do you have an HO Alternator because Most vehicle electrical systems are 12.5VDC at idle, only 13.8-14.4 above 900rpm |
Silver Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 494 Registered: Jul-05 | Also whats your budget |
Bronze Member Username: TjmutlowPost Number: 56 Registered: Sep-05 | those subs will never handle the power they are rated at, stay closer to the rms power and not peak |
Silver Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 500 Registered: Jul-05 | They should be able to handle 1500-1800 watts easy (together) |
Bronze Member Username: Alexv305Tavernier, FL USA Post Number: 26 Registered: Oct-05 | My car runs @ 13.8 volts. I do have the money to buy any amp I just want to know which one is gonna be the best.. |
Silver Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 509 Registered: Jul-05 | Please check this out http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic |
Silver Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 510 Registered: Jul-05 | hope this helps |
Silver Member Username: Iufan4lifeulPost Number: 566 Registered: May-05 | if you don't have at least a 160-180 amp alternator then you are upstream. |
