Is static distortion
Username: Cenus
Hicksville, Ohio Usa
Post Number: 525
is static that you hear when the radio is on is that distortion or just unwanted noise. in my car my speakers start to distort around 35 but i hear static around 25-30 so i went inside and tried it on my stereo and it useally starts to distort around 15 but i heared the static around 10 so is static distortion or just unwanted noise.
Username: Tdbdadrummer
Post Number: 474
That's the radio reception. If you want clean radio, satellite is the way to go, but even it has it's let downs.
Username: Taylor17
Kopperl, Texas
Post Number: 3115
Yeah, prob just unwanted noise.
Does it do it with a CD?
Username: Cenus
Post Number: 526
no when i put a cd in it sounds fine, but as soon as the radio comes on i hear it.
Username: Taylor17
Kopperl, Texas
Post Number: 3145
Yeah, its just bad reception.
My radio does it on certain stations... and only when the bass hits. If there isn't any bass, its clear.
