Amp?
Username: Killer44
Ontario Canada
Post Number: 183
What would be a good amp to run one Audiobahn ALUM12Q...also can anyone give me the dimensions on a ported box for this sub, (ie box size and port dimensions) thanx in advance
Username: Taylor17
Kopperl, Texas
Post Number: 3091
Whats you're price, and isn't that sub 6 ohms dvc?
Username: Killer44
Ontario Canada
Post Number: 184
yes it is(6 ohms dvc)....prob about around 400$, maybe alittle more...
Username: Killer44
Ontario Canada
Post Number: 185
http://cgi.ebay.com/AUDIOBAHN-A2601T-AMPLIFIER-2-CHANNEL-AMP-SUB-AMPLIFIER_W0QQi temZ5816057003QQcategoryZ48597QQrdZ1QQcmdZViewItem is this a good amp to run it with?
Username: Taylor17
Kopperl, Texas
Post Number: 3093
Isn't the rms on that sub like 900/1100 watts?
If so, that amp is way too small.
Username: Taylor17
Kopperl, Texas
Post Number: 3094
I can't find any amps that push that kind of power at that ohm, around $400.
If you had 2 subs, it would be easier.
I found a few that will power that sub, but they cost any where from $500/$800.
The problem with 1 of those subs is you're trying to find an amp that will push about 1000 watts rms, at 3 ohms. Most amps around that price range push that at 1 ohms.
Username: Taylor17
Kopperl, Texas
Post Number: 3095
lol
I spoke too soon.
I found 1 amp, the Hifonics BX2500D for $350.
Its not the best amp in the world, but it isn't in the same league as Sony.:-)
www.sonicelectronix.com is where I'm looking if you want to take a look.
Username: Tushmen36
I have a Jl 500/1 mono amp. I was wodering if its possible to hook that up to two subs. Please help really getting frustrated lol
Username: Tdisanto
Post Number: 364
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Killer44
Ontario Canada
Post Number: 186
so what ur'e saying is i gotta find a amp that runs about 800-1000wrms @ 3ohms? whats the lowest i could go(rms) w/ out hurting the sub(underpowering)...also if anyone knows of anyother subs that are cheaper feel free to mention them...thanks in advance
Username: Killer44
Ontario Canada
Post Number: 187
ne one...
Username: Killer44
Ontario Canada
Post Number: 188
sorry i meant, if anyone knows of any cheaper amps that will run the sub please mention them
Username: Killer44
Ontario Canada
Post Number: 189
http://cgi.ebay.com/KOLE-AUDIO-3000-W-Class-D-MONO-SUB-AMP-POWER-ACOUSTIK_W0QQit emZ5815342294QQcategoryZ18797QQrdZ1QQcmdZViewItem jsut found this on ebay...will it work?
Username: Killer44
Ontario Canada
Post Number: 190
ne one on this amp, or on another amp?
Username: Taylor17
Kopperl, Texas
Post Number: 3150
It didn't give any real info... but PA isn't that great of a brand.
I'd go with the Hifonics BX2500D, and then if you go and get another sub,, it will power both great.
Username: Killer44
Ontario Canada
Post Number: 191
ok i have found a few that will work...but i really want to know is what can i get away with using as far as rms goes, how low below the rms of the sub can i go...
