New member Username: IonlyknowyPost Number: 1 Registered: Oct-05 | I had a shop connect my system in my bmw 328i. They used a line converter in the trunk instead of running RCA cables from the head unit. At first everything worked good. now whenever I connect everything like it should it works, then I turn off my car and then when I turn it on again the speakers go full bass non stop and not with the music... I connected another amp and it did the same thing so I know it's not the gain on the amp that went bad... The shop put a pop filter to the amp to do away with the initial bass when you turn off the car... ever since they installed the pop filter it has been doing this non stop bass thing... I disconnected the pop filter and then it just doesnt work at all... what should I do?????? |
Gold Member Username: James1115Wilton, Ct Post Number: 3940 Registered: Dec-04 | buy a head unit with RCA's problem solved![]() |
