Whats the difference
sbrizzi
whats the difference between 2ohm and dual 2ohm or 4 ohm and dual 4 ohm in a sub
and does the amp have to be dual if the sub is dual
Username: Tdisanto
Post Number: 219
The difference is that the motor assemble has either one or two voice coils rated at either 2 or 4 ohm.
Your amp does not have to be "dual" is you have a DVC sub.
Basically is you have a DVC sub, it gives you wiring options. For example if you have a 1- 2ohm DVC sub, you could wire it in series to 4ohms or you could wire it in parallel to produce a 1 ohm load to your amp. Same applies with 4ohm DVC, except it would be 8ohm and 2 ohm respectively.
Username: Tdisanto
Post Number: 220
thats supposed to say "motor assembly"
