DEH-7700MP PIONEER QUESTIONS
Username: Makavelie187
Concord, California Usa
Post Number: 40
has anyone experienced any problems with this deck i have had mine in my car for a while now and every now and then my subs will just shut off and come back on later this time they haven't came on in 1 day and i check all of my wires and there find maby the deck is defective not turning on the amp. my amp doesn't even turn on so thers a signal thats not being sent to my amp from my deck dun know what it is, checked my fuses also any recomondations or answers thanks.
Username: Illuminator
Post Number: 1654
The remote wire (blue with a white stripe) is probably loose...
Post Number: 42
nope not that i check that don't know what it is
Duffman54
U may have a loose connection in your sub box. one of the cords came lose on mine and it toke an hour of looking to find it.If its not that and u have a singnal going to your amp it could be your rca grounded out some were or there could be something wrong with your amp at the worse.
Username: Thigpen
RVA, Va Usa
Post Number: 101
maybe your amps overheating and shutting off? which would cause your subs to shut off.. i have the premeir version of it and ive never had a single problem with it other than i havent figured out how to change the bass to my speakers
