03 passat GLX Monsoon cdplayer locked on SAFE
Katone
I m reposting this properly (I had it in the Jetta section.. but I own a passat)
So anyway, the radio on my 03GLX passat is stuck on safe.
not blinking or doing anything, just stuck on 'safe'.
I d like to be able to display the "1000", to enter my code (yes, I have the code), but I can t find a way to do that. The radio wont show '1000', all it shows is SAFE!!
leaving it on for an hour or disconnecting the battery didn't change anything,
any idea?
thanks all.
