Which components?
Fred000
What bands/models would you recommend for a good set of component speakers? My budget is about $500. The size would have to be 5 ¼" with good sound quality.
Thanks in advanced.
Username: Phoenix469
Warminster, Pa United States
DYnaudio system 220MKII You can get them new on EBAY for around 449 plus shipping. I have the slightly larger system 240mkII. Giving them 150 watts per channel and they sound FANTASTIC
Username: Mixmastaspig
Okanagan, B.C Canada
Post Number: 138
Check out some Helix brands, they are sweet.
www.audissy.com
then click on products! check out all speakers I will give you prices if you ask!
