Username: Iufan4lifeul Post Number: 507 Registered: May-05
Tuesday, October 04, 2005 - 00:35 GMT Ok, very sticky stuff too bad it keeps coming off... Right now I have the whole trunk lid pretty much covered. A few of the areas have been falling off quite often. They are the same areas over and over. They said to clean it before installing it and I did it. What should i do? Should I just whip out some good glue or something? Thanks for any advice.
Username: Iufan4lifeul Post Number: 508 Registered: May-05
Tuesday, October 04, 2005 - 03:13 GMT bump
Username: Basshead86 Ocala,
FL
Post Number: 1979 Registered: Aug-05
Tuesday, October 04, 2005 - 03:18 GMT haha, try Dynamat Xtreme.
FL
Post Number: 1980 Registered: Aug-05
Tuesday, October 04, 2005 - 03:20 GMT do you have a roller tool? those help TREMENDOUSLY.
Username: Iufan4lifeul Post Number: 509 Registered: May-05
Tuesday, October 04, 2005 - 03:24 GMT no, need to get one o0. Will a screwdriver work?
FL
Post Number: 1982 Registered: Aug-05
Tuesday, October 04, 2005 - 03:34 GMT i used a tablespoon when i couldn't find a roller tool(it was only a few very small pieces i put on) just put your thumb in the dip of the spoon, and press with the other side against the Edead. like this ssssssssssssssssss "Thumb" s s s s s s s ---------------------Edead--------------------
FL
Post Number: 1983 Registered: Aug-05
Tuesday, October 04, 2005 - 03:37 GMT Crap!!! i didn't work!!!! ssssssss-thumb-s --------s-----s ----------s-s ---------------------Edead-------------------- hopefully this one works. lol
FL
Post Number: 1984 Registered: Aug-05
Tuesday, October 04, 2005 - 03:38 GMT i guess you can't make pics with letters on this forum. oh well. lol i'm sure you get it, but i was bored and figured i try it out. lol
Username: Fandim Reno,
Nevada
United State...
Post Number: 249 Registered: Jun-05
Tuesday, October 04, 2005 - 04:19 GMT ---- --- --- edead --- ---- --- ========Spoon tip Thumb
Tuesday, October 04, 2005 - 08:55 GMT stick your thumb on your face
Username: Thumper Richmond,
VA
U.S.A
Post Number: 99 Registered: Apr-05
Tuesday, October 04, 2005 - 13:47 GMT try heating it (with a heat gun, or a blow dryer) and then applying it just to the areas that are falling off....with the spoon trick
Username: Lowrollins10 Champaign,
IL
Post Number: 133 Registered: May-05
Tuesday, October 04, 2005 - 15:08 GMT Just get some 3M 77 Spray adhesive..
VA
U.S.A
Post Number: 100 Registered: Apr-05
Tuesday, October 04, 2005 - 16:54 GMT or try licking it....
Username: Southernrebel Monroe,
Louisiana
Post Number: 1226 Registered: Mar-04
Tuesday, October 04, 2005 - 17:26 GMT i say try the 3M spray...or heat it a lil. i have heard quite a few of these "i cant get my edead to stick" stories on other forums. makes me glad i went w/ the "other" super cheap dynamat alternative. (peal-n-seal , but i only have like 25-30sq ft installed)
Username: Robert_d MIA,
FL
Post Number: 159 Registered: Sep-05
Tuesday, October 04, 2005 - 17:26 GMT lol ice
Username: Bloodywaters Post Number: 8 Registered: Sep-05
Tuesday, October 04, 2005 - 17:30 GMT tar + tongue = (oh, never mind...i'll pass)
Username: Invain Michigan
United States
Post Number: 3806 Registered: Aug-04
Tuesday, October 04, 2005 - 20:22 GMT You have to heat it or it'll come off after a month or two. I found out the hardway.
