I have an amp, woofer and 6x9s need help with connecting
Username: Jonzy007
I have bought a jbl amp recently. So far i have connected it to the head unit and about to connect it to the car battery. With regards to the 6x9s where do i connect them to is it the amp or the head unit do i need to do anything with the headunits wires in regards to the 6x9s or do i just connect them to the amp and they should play from there? PLease help i'm a amature
Username: Jonzy007
I also forgot to say that it is a ford fiesta and doesn't have rear speakers don't know if this makes a difference
Username: Tdisanto
Post Number: 70
you connnect the RCAs between the HU and the amp. Then connect the 6x9s to the amp only with speaker wire. The old speaker wire coming from the deck will no longer be used.
hope that helps!
