Help deciding on sub
hondaboy
I think i want one 15 for less than $300 that has good sq and is loud with around 600 watts rms
Username: Basshead86
Ocala, FL USA
Post Number: 1271
then have i got the sub for you.
Resonant Engineering SE
$199 before shipping
600wRMS:-O
www.reaudio.com
hondaboy
or would 2 REs be better?
hondaboy
or would 2 RE 12s be better?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 821
Muddy: you have that up for sale?
Ocala, FL USA
Post Number: 1282
your going from 1 15" sub that handles 600wRMS, to 2 12" that handle 175wRMS a piece.
i would go with the 15"
Ocala, FL USA
Post Number: 1285
no, it just sounded cool. lol
and i have always wanted to say that.Upload
Hondaboy
ya but i thought the 2 REs would sound similair to the one 15 and it would be about $100 cheaper because i could buy a 400 watts rms amp instead of a 600. So my question is will the SE 15 be that much better that the 2 REs?
Ocala, FL USA
Post Number: 1286
i think it would. i try not to buy entry level anything when i have the chance. not to say that the RE RE's are crap, but i would rather have a meaty single 15" than two entry level 12's.
just my opinion:-)
Ocala, FL USA
Post Number: 1287
however, if it works out better for you budget-wise, then go with the 2 12's and the 400 watt amp. it certainly won't be bad sounding, and will get fairly loud.
