15" or BIGGER I DONT KNOW VISONIK
CARAUDIO
I just got some guys 15INCH VISONIK SUB now im looking to see some pictures so i can match which one it is i havent had any luck any one is it good or what??
CARAUDIO
Looks somthing like this well exactally like this from the bottom
http://cgi.ebay.com/Subs-2-Brand-New-Visonik-V812D2-Subwoofers-5000-Watts_W0QQit emZ5810622468QQcategoryZ18803QQrdZ1QQcmdZViewItem#ebayphotohosting
Now that is 5000 watt sub:S wtff thing is i cant see the top of it has a small lil rectangle shapped box about 5X7 box with VISONIK written in it around that its a circle about 15cm in diameter thats black and rest around it is black. Its 11inches from inside the rubber to each end so i guess its 13inches or somthing.
CARAUDIO
Hers the top view. Website doesnt work but that small preview picture is it. http://images.google.ca/imgres?imgurl=http://www.mobileaudiospecialists.shopping cartsplus.com/i/Visonik/tn_SmallVISVB60.jpg&imgrefurl=http://www.mobileaudiospec ialists.shoppingcartsplus.com/subwoofers.html&h=100&w=89&sz=4&tbnid=glFYhtVsG8EJ :&tbnh=77&tbnw=68&hl=en&start=34&prev=/images%3Fq%3Dvisonik%2Bsub%26start%3D20%2 6svnum%3D10%26hl%3Den%26lr%3D%26sa%3DN
Now if the 2 match thats insane!!!!
CARAUDIO
Never mind yep it is the one in the EBay thing 2500Watt max power.
NOw let me hear the reviews any one??? Is it good or what? I got 2 Lanzar 124d's is it better then thoes??
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 55
why are u in this section got to the sub forum
anyway you got a lot to learn about watt rating that is very overrated even in max watts
CARAUDIO
my bad i thought it was the sub forum sorry.
