70003 Unregistered guest | My subs = 500 watts if I get a 850 watt amp will it blow my subs? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10077 Registered: Dec-03 | need more info. -how much RMS power can each sub handle -how many ohms per coil, and how many coils per sub? -what is the make and model of the amp and the subs? |
70003 Unregistered guest | M3151 Diamond audio subs 8ohm DVC 250 watts. Rockford Fosgate X6 BD Class 850 watt amplifier amp 850x1 at two ohms, 425x1 at four ohms. I'm not for sure about the RMS. |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1041 Registered: Aug-05 | read this page.![]() http://www.bcae1.com/speakrat.htm |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10083 Registered: Dec-03 | good match. 425 watts per sub. |
70003 Unregistered guest | so my 250 watt subs can handle 425 watts each. |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10091 Registered: Dec-03 | are they 250 per coil, or 250 total watts? if its 250 per coil, they're ok. otherwise, too much power. |
Silver Member Username: TdbdadrummerPost Number: 171 Registered: Aug-05 | Is it really too much power if you know not to set it at the amps RMS? I'd buy the amp, just for upgrade purposes in the future... |
70003 Unregistered guest | I think they are 250 watts total. Here is the manual http://www.diamondaudio.com/products/pdfs/M3submanual2a5.pdf |
70003 Unregistered guest | What is the most watts you would put to these subs? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10099 Registered: Dec-03 | http://www.wickedcases.com/caraudio/speakerpwr.html |
