Sony xplod cdx-l550x problem
Username: Juxbill
i have a sony xplod cdx-L550x and i hook it up. I did everything right. And when i play a cd on it it wouldn't work, but i can hear the bleeping noise. And the radio doesn't work also. IT says ATT. Please Help Me.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 774
ATT generally means attenuate. Read your manual.
sdfjsdalkfds
He probably hooked the ATT wire up to something.
Username: Mikechec9
Chicago/atlanta
Post Number: 779
att switches on my amps are used when a source output higher than 4-5volts is used.
e.g., if your HU is 6-10volts out, then the function allows you to compensate for it on your amp.
Username: Juxbill
i turn the att off and now i can't hear the music. all i hear is the bleeping noise. any ideas
