Sub placement
trickfly04
best place to put a sub in a 94 mustang convertable.
Compvr 12inch
HELP!!!!!!!!!!!
Username: Koveaudio
ported or sealed box?
trickfly04
Sealed Box, and now i have a 12 sony 1200peak 500rms?
BMan
In the trunk facing the back of the car.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1696
yup
against the area where the top goes, firing toward the tailgate.
that'll allow the sub to resonate in the trunk. should help.
other option is to port the box into the cabin.
tricky, lots of work, sounds great when it's done.
other option is to try a bandpass box to increase SPL to overcome all the metal you're going through.
