Hifonics amp for 2 jl w3 v2s
Username: Thugunlimitedx
Post Number: 9
whats the best hifonics amp for 2 jlw3v2 subs with dual 4ohm coils
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 102
if the jl's are 10" or 12" then an amp that would do between 500-700 watts @ 1 or 4 ohms. If they are the 15's then a 1000 watt amp at 1 or 4 ohms would be perfect.
Username: Carguy
Post Number: 3943
I'll say this since no one else is, Hifonics do not make great amps. They may be cheap in price and high in power numbers, but don't expect high quality.
I'd say they're good for SPL system at low price.
If you're going to spend money on JL subs, why not invest in a little better amp?
Username: Rovin
Trinidad & T...
Post Number: 117
Was about to say the same thing - if a guy can afford something from JL , why not get a JL amp or from a similiar/higher ranking company say MMATS , Zapco ,US amps or Arc audio ......
Post Number: 14
my brother got 2 12 jlw3v2s an box 4 like 50bucks an he had a payarmid amp powerin dem an wow it sounded amazing but the ohms killed da amp an blew da 1 channle so i guess hes better 2 get a 700wat hifonics amp at 1ohm 2 power them now
Username: Riebread77
Post Number: 568
zapco and us amps are a little out there for price range...he's not talking a w7 guys...not all jl subs all ridiculously expensive...
how bout instead of the best hifonics amp...you give us the RMS of the subs and your budget for an amp?
Post Number: 15
i dk no da rms an its not 4 me propley about 200 300
Username: Shocksyde
Post Number: 35
RMS power handling for a 12w3 is ~300 but they can handle more than that.
I'm giving my one around 375 watts
