Like
6.5 or 6x9
elmers
Hey, im looking to upgrade my stock speakers, and Ive got 6x9s right now, but ive heard that 6.5" have getter sound quality, so should I grab the 6.5"s and some speaker adapters or just stick with 6x9s
Username: Mikechec9
Chicago/atlanta
Post Number: 706
6.5's. lose the x9's if it's an option.
Username: Basshead86
Ocala, FL USA
Post Number: 351
definitely, 6x9's have the same SQ problem solo-barics have lol
Username: Jaackdeth
United States
Post Number: 543
What if your stuck with 4x6's up front in the dash, and you have 6x9's in the rear deck, would you go with componants in the rear then, or just replace the 6x9's with the 6.5's Brands?
Ocala, FL USA
Post Number: 388
just get a meaty pair of 6.5 components, and mount the tweeter in the c-pillar facing the front
http://www.reaudio.com/html/
check out their 6.5 comps
Ocala, FL USA
Post Number: 389
but ideally your soundstage should be from the front,i.e. when you go to a concert, does the band play behind you? lol
Username: Jaackdeth
United States
Post Number: 544
Oh I know, but this caddy is giving me so much trouble with speakers. I can't find anyone around my area to do custom kicks, and there is NO room on the doors, so they stuck them 4x6's in the dash! This is why I guess without spending a fortune on this ride, alternatives if any! The 6x9's I can get at better to in the rear, and running a sub in the trunk! Thanks for any input!
Username: Jaackdeth
United States
Post Number: 548
I will give RE a call tomorrow and see what they get for them.
Facebook
Shop Related Deals
Directory
