Premier Subs
Username: Atv_junky
Post Number: 11
i am putting together my first system and i would like something that is inexspensive and has SPL. would these subs be a good choice? Premier TS-W126C/DVC
also, what would be a good amp to get without spending a lot of money? i want 2 subs and they are 400w RMS
Username: 54danny54
Post Number: 879
huh lol
Username: Mike_anthes
Canton, SD USA
Post Number: 246
ok dude...how much money ya got to spend total...and tell us what u need exactly(subs, amp, cd player, etc)...
Username: Atv_junky
Post Number: 12
right now i am looking at subs and an amp. i have $200-$300 to spend on 2 subs and $500-$600 for the amp.
Username: Rovin
Trinidad & T...
Post Number: 82
Today a 'Rick Lussier' ask the very same ? on another post - here's what i said to him , only difference he asked about the Pioneers & u are asking about Premiers : but its the same 400rms each.
Those Pioneer(now $55 each , was $66)i have & its very loud/good bang for the buck subs (Actually i own pair of the TSW306DVC model , dual 4ohms).
Note though my ported box is currently tuned around 43hz but i intend to do it right & put a longer pvc pipe which will make it around 35hz as they rec .But i'm very satisfied what i got for the $ .
If u are after SPL mainly Y not get 2 of the Premier TS-W3004SPL ONLY $125 each online 1,000 wrms (install in a ported box) & get 2 ED 9.1 1200 wrms amps $350 each . Total budget subs/amps = $950 , u can't get anything near that power/price range & we're talking about 'good enough brands' here ....
Canton, SD USA
Post Number: 253
so in all reality you have 700-900 to spend...
i would just drop yur other idea and start fresh...y not get like 2 12" re sx's(around 275 each shipped) than get 2 hifonics bx1500d's(around 230 each shipped)...than 50 bucks for wiring...and another 50 bucks for box materials...and yur set...that should be a little over a grand...but that system would definatly put out enough sound for ya...if that costs too much than get like 1 re sx 15"(around 300) or 18"(around 350) and get one of these amps...
http://cgi.ebay.com/NEW-Kicker-KX1200-1-1200-W-MONO-SUB-AMPLIFIER-CAR-AMP_W0QQit emZ5793607503QQcategoryZ18797QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/NEW-ROCKFORD-FOSGATE-POWER-T10001BD-MONO-AMPLIFIER_W0QQitemZ 5794434826QQcategoryZ64572QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
^personal favorite
or you could go with a resonant engineering 12.1...which i think is around 400 or so...(then you would have a re amp and sub)
then 50 bucks for wiring...and 50 for box materials and you should be within yur range...
Canton, SD USA
Post Number: 254
and the rockford amp isn't 1000 watts max trust me...its rated at 1000rms @ 1 ohm...but it puts out much more than that...i used to have one pushin my old brahma 15" and it pounded the birthsheet said it put out closer to 1400 rms @ 1 ohm...although that was at 14.4 volts...
