What is the most important thing about a custom box.
Username: Mbenz10
Hey guys i'm going to make my own box with pliwood and some fiberglass. I was wondering what the most important thing to remember is when building a box.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 821
make sure it is air-tight and braced well.
Username: Tbolt
Collipark, GA
Post Number: 319
You might want to consider MDF instead of plywood. Its alot thicker and alot more durable.
Username: Mbenz10
Kewl, what could i use to make it air tight and are nails or screws better? And also do i have to suck up all the air out of it or something or is it just to make it sound better to make it air tight.
Username: Araknid
BOCA , FL U.S.
Post Number: 996
To make it air tight you wanna line the inside with caulking.
Username: Araknid
BOCA , FL U.S.
Post Number: 997
just like here...............
http://images.amazon.com/images/P/B0002ZPLQG.01-A385A0XNQBW8HY._SCMZZZZZZZ_.jpg
