New member Username: Lex2goPost Number: 1 Registered: Aug-05 | I already have the PPI PCX440 powering the interior speakers. I'm about to buy a PPI PCX480 to power 1 JL 10w3v2. My question is can I bridge the amp to run just one sub? I know I should get a 2 channel amp but I'm getting a good deal on this amp. Thanks in advance. Any help would be great. |
Bronze Member Username: Bryce_kOrlando Post Number: 21 Registered: Apr-05 | Ok I'll assume it's a 4ch amp your using. You could bridge 2 channels to the sub and have 2 channels unused, or if it's a dvc woofer you could bridge 2 channels to each voice coil,if the impedance isn't to low. |
New member Username: Lex2goBay Area, CA Post Number: 2 Registered: Aug-05 | I know this is a stupid question, but how do you wire a 4-channel amp to power 1 DVC (Dual Voice Coil) subwoofer, a JL Audio 10w3v2. I'm planning to buy the PPI PCX 480 but a couple of my friends are pushing me away from it. |
Gold Member Username: James1115Wilton, Ct Post Number: 3772 Registered: Dec-04 | well if its dual 4ohm then you wire one coil to the front two channels and 1 coil to the rear channel's both mono I believe that amp runs 320x2 bridged mono @ 4ohms, so that will fry the cr@p out of a w3. |
