New member Username: Punkbassist1989Post Number: 1 Registered: Jul-05 | ok so i just put in a brand new sound sytem of sony indash player and new speakers in my car. i was wondering if i should put 2, 2-channel amplifiersin-one for front and one for back, or one 4 channel amplifier. now basically it is a matter of if i use 2 amplifiers would i need another battery for the amplifiers because i also will put in another amplifier for 2 subs. thank you and hopefully you can help. |
Silver Member Username: ScubasteveAnnapolis, MD Post Number: 234 Registered: May-05 | Hey Jon, you'd be good with a 4 channel amp. If you tell us the specs of your new speakers we can advise you on an amp. If you have components up front, you also have the option of Bi-amping them, which means using a 4 channel amp just for the front speakers. Then you can get another 2 channel amp for the back speakers, or, if it were me, I'd just power them with the HU or not even use them. Also, you won't need a second battery. It will do you no good. What you need is a high output alternator if your car starts to show signs of sagging voltage rails. |
New member Username: Punkbassist1989Post Number: 2 Registered: Jul-05 | (here are the front speakers) http://www.circuitcity.com/ssm/Sony-6-1-2-Speakers-XSV1630A-/sem/rpsm/oid/86767/ rpem/ccd/productDetail.do (here are the back) http://www.circuitcity.com/ssm/Sony-6-x-9-Speakers-XSV6930A-/sem/rpsm/oid/86768/ rpem/ccd/productDetail.do thank you any help would be great. maybe even some amplifier recomendations i want all the power out of my speakers and i dont want to blow a hole in my pocket. thanks and again any help would be great. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8487 Registered: Dec-03 | 4 channel amp for fronts/rears mono class D amp for subs |
New member Username: Punkbassist1989Post Number: 3 Registered: Jul-05 | any recomendations for amps..im just getting into this stuff and dont know about it yet. so any recomendations would help. i would like to get all the power i can out of my speakers but dont want to spend more than 600 for the amps |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8499 Registered: Dec-03 | Kicker kx600.4 and kx600.1 |
New member Username: Punkbassist1989Post Number: 4 Registered: Jul-05 | what are you peoples thoughts on the sony xplod amplifiers good, bad, reasonable for price because im looking to hook up 2 sony 12" subs and thought maybe a whole sony system so what r your thoghts on that |
New member Username: Punkbassist1989Post Number: 9 Registered: Jul-05 | Anybody know any places like wholesale where i can buy ams and subs for cheap |
Silver Member Username: Alias747MN Post Number: 538 Registered: Apr-05 | Well.... Sony amps are complete junk. Stay away if you haven't already bought it. I personally wouldn't use anything made by Sony for car audio. |
Bronze Member Username: Punkbassist1989Post Number: 12 Registered: Jul-05 | well then what r ur recomendations for amps and or subs that are reasonably priced i dont want to spend more than 300 dollars for 1 amplifier |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8505 Registered: Dec-03 | sony everything for car audio is crap, as far as current products go. look at JBL for amplifiers that are good and affordable. look at Kicker CompVR subs |
New member Username: GhowardsClark, SD USA Post Number: 3 Registered: Jul-05 | hey I just started getting interested in sound systems and im kinda dumb at it so I appreciate any help and your patience. I am looking at buying 4 rockford fosgate 12'' stage 2 subs which run at 200rms and 400 peak will I be able to power them with a 1200 watt rockford fosgate 4 channel amp? I greatly appreciate any advise or feedback you guys have. Thanks |
Silver Member Username: ScubasteveAnnapolis, MD Post Number: 235 Registered: May-05 | garett, unless you have an electrical system than can handle the draw of a A/B 4 channel amp like the one you mentioned, you're better of with a Class D mono amp. It'll draw 20-30% less amperage for the amount of power it produces. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8524 Registered: Dec-03 | if you want 4 subs, use a class D mono amp. not a 4 channel. it'll draw less current that way as noted above. get 2 ohm SVC subs, or 4 ohm DVC subs (same end result) if you want four subs on a 2 ohm stable mono amp @ 2 ohms final load. |
New member Username: GhowardsClark, SD USA Post Number: 5 Registered: Jul-05 | k like I said im pretty new so I do appreciate your help. They guy I bought it from said if I bridge it at 2 ohms I can get 2300 watts I dont know if that matters. Second thing is if my electrical system cant handle it, would a HO alternator be an option? what are some examples of a class D mono amp. The thing is I wasnt thinking real hard and already bought the amp, so what combination of subs would produce the best result? thanks a bunch guys I really appreciate it. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8629 Registered: Dec-03 | give me the make and model of the amplifier. I'll tell you how much power it really has and what it can run. you want four twelves? |
New member Username: GhowardsClark, SD USA Post Number: 6 Registered: Jul-05 | which combination would be louder? four subs with the mono amp or four subs with a different combination. I have a pretty high budget so lemme know. Thanks |
New member Username: GhowardsClark, SD USA Post Number: 7 Registered: Jul-05 | the amp is a rockford fosgate punch p4004 1200 watt amp. I would like to get four twelves unless you dont think its worth it. Also I saw earlier you told jon stanton to use a 4 channel amp for his front and rear speakers. I am also planning on replacing my front and rear speakers so should I use that amp for the front and back and get a mono class D amp for the subs? |
New member Username: GhowardsClark, SD USA Post Number: 8 Registered: Jul-05 | here is what the actual amp is http://i20.ebayimg.com/04/i/04/83/9c/39_0.JPG |
New member Username: GhowardsClark, SD USA Post Number: 9 Registered: Jul-05 | http://i20.ebayimg.com/04/i/04/83/9c/39_12_sb.JPG |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8637 Registered: Dec-03 | use a 4 channel for components and a mono amp for subs. yes |
Sonnyboi Unregistered guest | i just bought 2 Kicker Solox 12's and i have a custom box. what type of amplifiers should i use and how many should i run to each sub? |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8689 Registered: Dec-03 | if you have a pair of dual 4 ohm coil subs, the Kicker SX1250.1 or KX1200.1 would be ideal |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8690 Registered: Dec-03 | oh you said Solo X I was thinking L7 what's the coil config on each sub? |
New member Username: GhowardsClark, SD USA Post Number: 10 Registered: Jul-05 | ok so if I do four 12's how big of a mono sub would I need or am i better of just doing two 12 inch subs and if I am how big of an amp should I use and also do you have any reccomendations for brands. Since I already have a rockford amp should I keep the same company or doesnt it really matter to mix and match |
Bronze Member Username: GhowardsClark, SD USA Post Number: 11 Registered: Jul-05 | The four 12's I am looking at are these: Punch STAGE 2 4 ohm 8" Component Subwoofer molded polypropylene woofer cone 60 oz magnet frequency response 20-200 Hz power range 50-150 watts RMS sensitivity 83 dB top-mount depth 3-13/16" sealed box volume 0.25 cubic feet ported box volume 0.65 cubic feet what would I need to power those? http://www.mmxpress.com/rock_subs.htm |
Bronze Member Username: GhowardsClark, SD USA Post Number: 12 Registered: Jul-05 | I know you guys are getting sick of me but I really appreciate it. Can I run four 12's with one mono sub or would I need like two 300x1 amps? |
Bronze Member Username: GhowardsClark, SD USA Post Number: 16 Registered: Jul-05 | what would I need to power four of these? Punch STAGE 2 4 ohm 12" Component Subwoofer molded polypropylene woofer cone 60 oz magnet frequency response 20-200 Hz power range 50-200 watts RMS sensitivity 86 dB top-mount depth 6.1" sealed box volume 0.85 cubic feet ported box volume 1.25 cubic feet |
Silver Member Username: ScubasteveAnnapolis, MD Post Number: 299 Registered: May-05 | Garett...I answered that question on the other tread where you asked the exact same question... https://www.ecoustics.com/electronics/forum/car-audio/151096.html Does that ring a bell? |
Bronze Member Username: GhowardsClark, SD USA Post Number: 19 Registered: Jul-05 | hey guys, class told me to get 4ohm DVC and get a 2 ohm stable amp, but steve told me that my wiring options are 1 ohm or 4 ohm and I was just wondering which one to do so I can get the right amp. Also does anyone have a link to the thread where glass explains how to figure out different wattage for different ohms and such? |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8763 Registered: Dec-03 | Garett, www.bcae1.com has sections for computing load for amplifiers based on the speaker impedances. it teaches you everything you need to know.. just take about a day to read the site.. you'll be amazed how much you learn there I know the author of that site, and he's done a terrific job of building the best site I know for learning all the basics of car audio and electronics. |
Bronze Member Username: GhowardsClark, SD USA Post Number: 20 Registered: Jul-05 | thanx glass I think that site is exactly what I needed |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8831 Registered: Dec-03 | it's one of my favorites ![]() |
