What gauge wire for Wiring IDQ 12 D2 v2?
Naras
I want to wire 2 ohm DVC to get 4 ohms and i am aware of wiring diagram but i just don't know what gauge wire to use.
Does 12 Gauge wire wille be fine?
Do i need to solder the ends?
Please help
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8469
12AWG is more than good.
16AWG would work sufficiently in reality, but for show factor, sure go with 12ga.
Naras
I got 12AWG wire from CC, it's blue&white twisted pair, should i use twisted wire or just one of the wire from the pair.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8480
twisted pair is fine.
soldering is up to you
Naras
Just one more question
I have IDQ 12 D2V2, RMS recomended is 350.
My Amp outputs 400 RMS in bridged mode.
What AWG to use from speaker to terminal cup?
Thanks
