Wiring blaaa
Username: Bigred2069
Post Number: 49
right now i am driving a van, but it is on its last legs. my uncle gave me an 86 grand prix, but it is uninsured and it is illegal to drive w/o insureance here. i have been looking in it and i have nooo idea how i am going to get the power wire from the battery to the trunk it looks nearly impossilbe. in the van everything was as easy as could be. the grand prix is kinda like an old cadilac, same style basically. any common ways to get the power back there?
Username: Jaackdeth
United States
Post Number: 254
LOL, I have one of those OLD caddilacs! I found a spot, every vehicle has a plug for wiring to go through, some are hard to find (MINE) but got 0 gauge back there!
Post Number: 50
yea i got 0 gauge too, ive been lookin around idk man. where was ur spot?
Username: Jaackdeth
United States
Post Number: 255
Right below the master cylinder!!
Post Number: 52
hmm alright ill check it out, i really hope it works for me to hahaha, thanks
Username: Invain
Michigan United States
Post Number: 3252
You can always drill a new hole in the firewall...
Post Number: 53
yea i was thinking about that, is that bad for your car in anyway?
Username: Invain
Post Number: 3254
Not really.
Post Number: 54
alright sweet thanks
Username: Big_oso
Post Number: 180
The only thing is if you drill a hole, you better seal it up after you've run your wires so no moisture can get in there. Either use a rubber gromet or you can just silicone it after its run
