Pre Fab Box ??'s
Username: Bassbeat208
U.S.A.
Hi I was wondering if my thoughts are correct. I'm looking at a Sub box that has 1.42 cu. ft. per side. But the subs I'm planning on putting in there take anywhere between .80-1.10 recomended range. So What I was thinking, I could put some mdf or other types of wood and screw it on the bottom. Would it still sound ok, or should I leave it with the extra space?
Thanks
Username: Kd7nfr
Montpelier, ID United States
Post Number: 203
You can mount a block of wood inside it and it should work just fine.
