Kenwood KDC-MP228 keeps shutting down
munjal
I have a Kenwood KDC-MP228 cd receiver and a Rockford Amp and 2 12' JL subs every time I start the system it keeps shutting down I have to reset it.
Did I do something wrong.
Username: Illuminator
Post Number: 695
Not at all, the unit could possibly be failing from bad parts.
munjal
so should i try geten a new HU
munjal
as loong as i keep the volume at 0 it will work but as i put the volume up it shuts down
Post Number: 696
It's a newer unit, though it is one of their cheaper ones...that's up to you, personally, I would buy a new unit. Perhaps one with a bit more reliability i.e. Pioneer Premier, Clarion ProAudio, Eclipse, Alpine(the models without recalls).
Post Number: 697
"as loong as i keep the volume at 0 it will work but as i put the volume up it shuts down"
It sounds like you know what you're doing, but have you checked the wiring and the speakers? And how long has the unit been doing this?
munjal
all the wiring were done by a pro but i am runing the factory acord speakers cud they be causing this its been doen it fr a month
Post Number: 700
Ah, then it probably is the headunit, can you get it serviced somewhere local?
