New member Username: AdamalpinedupPost Number: 1 Registered: Jun-05 | Hi folks..... A newbie here so thought id pick ur brains for sum much needed help. Recently bought an Alpine MRD-M1000 Mono amp and a pair of 12" Alpine R-type subs boxed etc (2ohm ones)...now finally after being hooked up to run them 2ohm etc...it seems they just dont sound right..i dunno maybe as if they not in sync??? hmmm need help guys and gals. http://www.yourcarparts.co.uk/trolleyed/images/products/mrdm1000.jpg Cheers Adam ![]() |
Silver Member Username: ThrushdtdNew York Post Number: 115 Registered: May-05 | what doesent sound right? |
another noobie Unregistered guest | i was gonna get the same set up.. is it loud?? |
New member Username: AdamalpinedupPost Number: 3 Registered: Jun-05 | well the base tbh lol... it just dont go in key sumtimes with songs etc. What way would you hook these subs up to the amp running the 2ohm? I was told two ways..one being positive to positive and negative to negative or loop them on the actual subs etc and to amp. My mates has a pair of mac audio the 300rms ones and they seem to defo out booom these hmmmm.... cheers adam |
