Bronze Member Username: Tatortot324Post Number: 36 Registered: Apr-05 | ok ive been looking at 3 amps to purchase for my 2 audiobahn alum12q there 1000 watts rms and 2000 watts max MTX THUNDER 1000D AMPLIFIER 1500 WATTS Mono amp Rockford Fosgate 1501BD Power Amplifier 1500 Watt MOno amp 2005 ALPINE 1000w DIGITAL MONO CAR AMPLIFIER mrdm1005 |
Gold Member Username: CarguyPost Number: 3301 Registered: Nov-04 | Digital amps aren't good for subs. They may look good on paper, but in bass world, it doesn't perform well. Go with MTX. It's cheaper than RF. |
Bronze Member Username: Tatortot324Post Number: 37 Registered: Apr-05 | Would there be any other amps better than these ? that will push my audiobahns? |
Bronze Member Username: Tatortot324Post Number: 41 Registered: Apr-05 | is there any other good ones out there i should take a look at also i dont wanna fry my Subs so whats the best Rms wattage i should get on a mono amp? |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 178 Registered: May-05 | rms plus 50%. set gains. rule of thumb |
Bronze Member Username: Tatortot324Post Number: 42 Registered: Apr-05 | well what Mono amp would you recommend for 2 audiobahn 12 alum qs 6ohm dual voice coil 1000 watt rms 2000 watt max subwoofers |
Silver Member Username: Alias747MN Post Number: 235 Registered: Apr-05 | So you have 2 dual 6 ohm subs??? Your going to have to get a mono amp that is 1 ohm stable. Make sure you look for that. Then wire the subs parallel/parallel for a final 1.5 ohm load. That is the only way to do it. |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 182 Registered: May-05 | Elemental Designs Nine.1 (again) http://edesignaudio.com/category.php?type=amps 1200x1 @1ohm 350.00. free shipping. excellent warranty. |
