Sean question about sub box.
Username: Junior11124
NyUs
Post Number: 27
is this a good box for the mtx 8000 sub 5/8" & 3/4" MDF construction
Sealed with a hot melt adhesive
Charcoal grey automotive carpet
Gold terminals
Divided chambers
1.25 total cubic feet per chamber
9-1/8" mounting hole
Tuned to 58 Hz
32" wide x 13" high x 13.5" deep
Approx. Weight: 42 lbs Upload
NyUs
Post Number: 28
if is not a good 1 for it pls give me the spe. for it pls
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 349
im assuming your talking about an 8500 and they are 10" woofers? the box should be fine for them..also 58 hz is a high as tune so dont plan on hitting any of those low notes ie. lil john
NyUs
Post Number: 36
no ,,,, is the thunder8000 10" subs so what do u recomend for it . what hz ?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 162
32Hz is the where I like 'em.
Username: Insearchofbass
Post Number: 2751
that isnt a good box for them 2 cf per would be good ported if you want really good response out of them
Post Number: 2752
and port them bad boys to 26 hz
Post Number: 2753
13.5 high 28 wide 21.25 deep with three 2 inch ports per sub 18.25 deep all this is internal measurements (i didnt include a divider)
external measurements using .75 mdf are 15 high 29.5 wide 22.75 deep
all displacement for ports and subs accounted for just drop the subwoofers in and enjoy
Post Number: 2754
youll be ported to 26 hz
NyUs
Post Number: 37
ok how about this 1 ALL 3/4" MDF construction
Gold terminals
Divided chambers
36.75" Long Slotted Port
1.75 total cubic feet per chamber
32" wide x 14" high x 18" deep 32hz
Post Number: 2761
that box looks good all except for a nice hump from 35 hz to 50 hz
Post Number: 2762
another thing you might run into is port whistle if the port isnt big enough
