Question 1sub vs 2
ok, im trying to get something straight here.. if i wired 2 subs up to ONE amp in parallel vs wiring 1 sub up to one amp in parallel, would the difference be 3dB?
on a side note.. what if i wired 2 subs up to 2 amps of the same power rating, would the difference still be 3dB? im reall confused on this whole issue lol
Username: Taylor17
Kopperl, Texas
Post Number: 1819
just adding 1 sub will add around 3 db's. Ok... then when you double the power... thats another 3 db's.
So, just adding another sub, will give you 3 db's.
Then wiring it to a separate amp... doubling the power... theres another 3 db's.
