Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 227 Registered: Nov-04 | I know that you drive a neon and so i thought i would ask you. I have a neon and i installed an 10" subwoofer and im running it with 100 watts in a sealed box and it sounds like my car is going to fall apart. sounds like the trunk is rattling to death is your car this bad? Im afraid to install the system im almost done building in fear of my car breaking just wondering if yours was this bad |
Silver Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 375 Registered: Sep-04 | what sub with 100 watts ratles your car so bad? lol |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3485 Registered: Dec-04 | yea, i put 120 square feet of edead, and it still rattles to cr@p, its NUTES, it really really makes me mad, i really need a tip to fix it, its crazy lol |
Gold Member Username: CarguyPost Number: 2957 Registered: Nov-04 | Subfanatic, have you thought of making a port into your cabin? The rattling will be far less if you let the bass "escape" via hole/port. I removed my rear speakers and used the holes as a "port". It got rid of the rattling by 30%. It also makes the bass sound louder in the cabin. |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3488 Registered: Dec-04 | isaac, would you like to see a pic, lol i dont have, but that is EXAACTLY what i did, lol. |
Gold Member Username: James1115Wilton, Ct Post Number: 2967 Registered: Dec-04 | does it get any better when you fold down the rear seats, because I know you can fold them down. When I first met my wife she had a neon and I put a system in it (1-12) and it rattled the sh!t out of it. I made it much better by going in and tightening every bolt that I found very well and it really helped it out. I had to repeat this about every two months or so but it did make an improvement. |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3503 Registered: Dec-04 | lol yea i did all that too, but putting the rear seats down amkes it worse cuase i can hear it even more lol |
Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 229 Registered: Nov-04 | 1 kicker comp 10" and yea folding the seats down sucks :/ |
