Atlas 15" Problem
Username: Sx3
Post Number: 51
I just instaled my 2 15" Atlas' using an Audiobahn A8002T to power it. It diden't really sound that good beacause it was only getting 200w RMS at 4ohms. I switched it to power just one sub at 800w RMS and it now has too much power plus I'm not even using the outher 15". I need a recomendation for a good amp to power both subs at around 500-600w RMS at 4ohms. Any suggestions?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 315
yes, how about less power... you do not need 500-600 watts for the atlas's... if i were you i would get a zapco reference 500... wire the subs in parallel which will give u a 2 ohm load... thats 250 watts rms to each sub... but actually the zapco amp probably will give you around 350 watts each sub... it is highly underated.
you can find it at www.woofersetc.com
Username: Sx3
Post Number: 52
is there anything closer to $200?
Username: Subfanatic
Walton, Ky
Post Number: 3377
interfire IB2900C amp, 225 bucks shipped 225Wx2
Username: Sx3
Post Number: 53
where can I find that at?
Walton, Ky
Post Number: 3378
i have it for sale lol, but i wish i knew a place that sold them, i want to find a few of there other amps
Username: Sx3
Post Number: 54
Why did it sound so bad when I had 200w RMS going to each? Was it just beacause the amp isent that good?
Walton, Ky
Post Number: 3380
yea audiobahns are to great, what kind of box do u have?
Username: Sx3
Post Number: 55
It's just a sealed box with like 2.45 cubic feet each chamber.
Walton, Ky
Post Number: 3386
that amp is overrated
Username: Sx3
Post Number: 56
which one is overrated?
Walton, Ky
Post Number: 3388
audiobahn, the interfire is severly underrated, its pushing my Ti right now
Username: Sx3
Post Number: 57
Yeah, I think the Audiobahn A8002T I have is terrible. It uses so much power.
Walton, Ky
Post Number: 3391
thats no good
Username: Sx3
Post Number: 58
What other amps are good for around $200?
Walton, Ky
Post Number: 3392
uh, how about a hifonics lol
Username: Sx3
Post Number: 59
which one lol
Username: Sx3
Post Number: 60
Would the HIFONICS ZX7500 sound good?
Username: Sx3
Post Number: 61
anybody got any ideas?
Username: Alpineuser
Winchester, TN
Post Number: 304
jbl bp600.1
Winchester, TN
Post Number: 305
"I just instaled my 2 15" Atlas' using an Audiobahn A8002T to power it. It diden't really sound that good beacause it was only getting 200w RMS at 4ohms"
um how do u have them wired? atlas is a SVC 4 ohm sub and 2 wired parallel is a 2 ohm load
Username: Carguy
Post Number: 2858
Shane, A8002T is a class AB amp. So yes it will use lot of current as you increase the volume.
If your subs are 4ohms DVC, then you should get a lot more than 200w per channel. 4ohms DVC will be 8ohms or 2ohms.
That is not a bad amp. If your alternator can supply the power, it will perform.
Username: Insearchofbass
Post Number: 1917
i agree i have messed with that amp and it does put out what i would call a true 600 rms not 800
Username: Sx3
Post Number: 62
How exactly do I wire it for a 2 ohm load? lol
Username: Sx3
Post Number: 63
Is it possible to just hook both of the subs to the same bridged terminal or is that not a good idea?
Username: Sx3
Post Number: 65
does amybody know?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1239
You'd have to run them in series which isn't always such a good idea. You wouldn't get any more power than running them in stereo anyways.
I'd think a pair of Atlas 15's would sound ok with 200 watts each. Maybe not.
-Fishy
luis gunny
that amps specs are:
2x400w rms @ 2ohms
2x200w rms @ 4ohms
1x800w rms @ 4ohms
and then it says that its not bridgeable at 2ohms??? so i don't think you can use that amp in a 2ohm load
luis gunny
2x400w rms @ 2ohms
2x200w rms @ 4ohms
1x800w rms @ 4ohms
* Also this is off the topic of this thread(sorry) but what do you guys think will be better(sq and spl) 2 15" atlas's or 1 15" avalanche
luis gunny
2x400w rms @ 2ohms
2x200w rms @ 4ohms
1x800w rms @ 4ohms
