Bad Memory Wire
Username: Black013
My memory wire bad on my harnees in a 83 custlass brougham be cause eveytime i cut the car off and cut back on the clock says 12:00 and my settings are erased I was wondering how can make my own memory wire can I run remote wire from the batter or something?
Username: Illuminator
Post Number: 111
Yeah, you can run new wire from the battery, but you might want to use a somewhat thicker gauge wire than remote wire.
