SPL difference in jl 13w7 and kicker 12L7
Username: Mcazayoux
New roads, La United states
Post Number: 22
which hits louder?
Username: Sploosh56
Ohio
Post Number: 571
13Wy by far
Username: Jthree
Bay area, Ca Usa
Post Number: 26
thats easy the w7. but if i was you i would still go with the eclipse titanium 15 that thing will kill the w7, expecially because of the price difference
Username: Insearchofbass
Post Number: 1319
you can hit 150db with the ti if you set it up right which will hold right with the jl 13 w7
Username: Jonathan_f
GA USA
Post Number: 3711
I posted on the other post.
The W7 would do best sealed over a wide bandwidth.
Ported with lots of power, the L7 would edge out the W7 due to the surface area and motor strength.
Username: Subfanatic
Walton, Ky
Post Number: 2289
sean, i completly owned a 12w7 with my ti yesterday, this sub is GODLY lol, its amazing, im def saving up for a second one, oh yea, and did i mention, i killeed the w7 with a 1000/1 and i was using a 600 watt rms audibahn amp
