12" Atlas or 12" Eclipse ???
Username: Tpizzle
Post Number: 75
what should i get, going for sq and durability.
12" Atlas $145
12" Eclipse 7124DVC $210
any recommendations? please tell why too. i keep going back and forth
Username: Subfanatic
Walton, Ky
Post Number: 2265
go with the atlas lol, use the extra money on an awesome box lol, personally the 7100 model numbers i dont like, the 88100 is where its at for eclipse
Username: Invain
Michigan United States
Post Number: 2074
Any reason why you don't like the 7100 models, or are you talking outta your butt? Just playin' Sub. I know your racist agains any other sub unless you've owned it, lol.
Walton, Ky
Post Number: 2267
ahha this is true, but i have heard the 7100 model and its just not worth saving the 30 bucks from the 88100 lol
Username: Invain
Post Number: 2076
Well yeah, I know the 88100's are a little better. Power handeling is 50 watts more, and I think they actually have a little more xmax.
Username: Tpizzle
Post Number: 78
cool ill go with the Atlas, you said get a good box where should i buy from and what square feet should it be. Probably sealed right, it sounds cleaner?
Walton, Ky
Post Number: 2270
i can build you a sealed one for 50 plus shipping if your intersted
