Username: Vwgn Post Number: 10 Registered: Apr-05
Sunday, April 17, 2005 - 07:32 GMT without a crimping tool? how to...thanks
Username: Fishy Tamarac Ft.Laud,
FL
Post Number: 963 Registered: Sep-04
Sunday, April 17, 2005 - 10:32 GMT It ain't always pretty but I've used a mongo set of channel locks before. -Fishy
Username: Theelfkeeper Stockbridge,
GA
Post Number: 297 Registered: Feb-05
Sunday, April 17, 2005 - 11:03 GMT hammer and center punch also works
FL
Post Number: 965 Registered: Sep-04
Sunday, April 17, 2005 - 11:22 GMT Yeah they have a special crimping tool for larger gauges that uses the hammer/punch method. You screw it down tight on the connector, hit it with a hammer, then rinse and repeat till you get a solid connection. -Fishy
Username: Nitescort Post Number: 58 Registered: Mar-05
Sunday, April 17, 2005 - 13:00 GMT metal vise.
