when an amp says that it is like 2 ohm stable does that mean each channel is 2 ohm stable, i have an amp that says 2 ohm stable and 4 ohm brigeable ?????????
ok well would it be better for my amp to be in stereo mode or in bridged mode and does stereo mode mean that it wants 2 ohm per channel of 1 ohm per channel to = a 2 ohm load total(channels combined)
Most amps run as low as 2 ohms on each channel. When you bridge an amp both channels are running together at 4 ohms. If you bridge at 2 ohms each channel is running at 1 ohms.Not good can burn the amp up. Stereo mode or bridged mode, I think most run speakers in stereo and subs in mono or bridged.
