Like
Neon in rear
In the back of my Tahoe i want to put some neon lights. Is there anyway of powering the lights without running the wires from my ciggarette lighter, can i use my amp power or something?
Username: Marley289
Post Number: 147
i think if you hook them up right, you can hook them up to the remote starter wire. im not too sure but i thought id try to help.
Username: Hittmann
Adelaide, South Australia Australia
Post Number: 16
yeah just hook em up to that remote wire you may need a small distribution block depending on how many you want to run. If the neons dont have built in fuses then an inline fuse for each neon may be a good idea also.
Facebook
Shop Related Deals
Directory
