Alternate placements for components
Username: 1stimer
OK...so I've been doing a little research about kickpanel pods, and I don't think I can do it in my w123 mercedes. The problem is the foot operated e-brake. what would be the 2nd best choice for placement. or should I just go with coax?
Username: Jwbulger79
Florida
Post Number: 311
kicks were not an option for me either. i put mine in the front-bottom corners of my doors and angled the tweeters up towards the middle of the front, at ear level. imaging is pretty good actually. one day i'll probably try to make a spacer that angles the midrange up and back a little also, but for now it sounds pretty good.
www.cardomain.com/memberpage/803011
yadda tadda
im sorry, im not very familiar with the 123'S, so i cant help you on that, however i am familiar with the 456's if you have any questions???
