New install
Username: Jbaker97
Houston, Tx Usa
Post Number: 8
I just installed 4 rockford stage 3 10" subs in the back of a honda civic coupe and I already had kicker 8" freeairs on the back deck. Would venting the back deck make a difference?
Username: Jmloughrey
Farmington, CT
Post Number: 993
...thats just stupid...
Username: Jbaker97
Houston, Tx Usa
Post Number: 9
Why?
Username: Jbaker97
Houston, Tx Usa
Post Number: 10
should I take out the 8s they are not being used for bass.
Username: Tragedy
San Jose, CA
Post Number: 76
yes take them out..
Username: Tragedy
San Jose, CA
Post Number: 77
then put grill cloth over the openings in the rear deck.. allowing the trunk to vent into the cabin. You will notice a greater dB increase
