I will list the specs of all the components. It's either gotta be one set or the other set, I can't mix the subs and amps.
Volfenhag ZX-4712 1000 watt sub(I'll need 2): Power(max):1000w Aluminum Cone 4 Ohm + 4 Ohm Dual Voice Coil Aluminum Diecast Chrome Basket Usable Impedance:2-8 Ohm High Temp 4-Layer Voice Coil Double Damper Bumped and Vented T-Yoke Double Stack Magnet Structure Push Type Terminals Free Air Resonance:30Hz Total Speaker Q:.526 Electrical Q:.614 Mechanical Q:7.698 VAS:56L Efficiency(1w/1m):89.58dB Piston Surface Area:.0491m DC Resistance:3.2 Ohm Dual 4 Ohm Nominal Impedance Continuous Power:500 w Mounting Depth:160mm Mounting Diameter:282mm
Volfenhag ZX-8400 2000 watt 2 channel bridgeable power amp:
Tri-Mode Capability 2 Ohm Stable Stereo RCA Input, Low & High By Pressing Switch RCA Preamp Line Output Selected X-Over HPF/FULL/LPF: HPF:50Hz-1KHz FULL:15Hz-30KHz LPF:30Hz-500Hz Adjustable Input Sensitivity(.2v-6v) 0dB & 18 dB Bass Boost Remote Bass Control w/20 Foot Wire 2 Ohm Stereo/4 Ohm Mono P.W.M Mosfet Power Supply Soft Delayed Remote Turn On Ultra Slim 1 1/4" Height Easy Install Dual Color Indicator LED(Power and Protection)
Now the other choice,
AW1251T Subwoofer Specification
TWO 12" High Performance Audiobahn AW1251T Subwoofers 800-watts MAX Power Handling EACH SUB (1600W TOTAL) 400-watts R.M.S. Power Handling EACH SUB (800W RMS TOTAL) 45oz Strontium Magnet Freq Response: 30Hz - 1kHz Efficiency: 91.1dB Phat Foam Surround Poly-Coated 2 Layer Non Pressed Non Transfer KM3 Coated-Cone for Virtually No Cone Distortion 2" four Layer Black Aluminum Voice Coil Nice Dual 4 Ohm Voice Coils The Mounting Dimensions: Depth; 5 1/4" Hole; 10 7/8" Diameter; 12 1/2"
BOSS CHAOS C700 Amplifier Specifications
2 Channel MOSFET Bridgeable Power Amplifier with Remote Subwoofer Level Control
SPECIFICATIONS
BOSS CHAOS C700 BRIDGEABLE MOSFET AMPLIFIER
Max power, 2 ohms 600w x 2 RMS power, 4 ohms 200w x 2 Bridged power 1200w x 1 Signal-to-noise ratio 102 dB THD 0.01%
